200 gt johnson flat bulb
stantheman
I have a 200 gt johnson 1987 , I have to pump the fuel bulb every time i want to start the motor. Even if I just stop for 2 or 3 minets.If I dont pump it up It wont start.Sometimes I pump it and it still dies when I give it the gas and I have to repump it.Runs good once its on plane. Also starts surging at top end untill it dies. I have a new non oiling VRO I mix in the tank. All 6 carbs have been rebuilt ( did not replace floats). New fuel line and bulb, There are no fuel leaks. new plugs installed,compression is good, runs cool, This problem has stumped some good mechanics encluding my self. am concedering putting a pump in place of the bulb. Hope you can help
jtexas
Re: 200 gt johnson flat bulb
Did you get the BRP brand bulb - the aftermarket brands don't have a good reputation.
Replace the fittings on the tank and on the engine.
fireman57
jtexas is spot on. Sounds like you are pulling air from a bad fitting in an aftermarket line. If you know someone who has another tank try it and see if that fixes your problem.
tashasdaddy
DOUBLE POST, let this one die.
