  #1
Old July 19th, 2007, 08:18 PM
Buttz Buttz is offline
Default carb issues
I have a 89 bayliner with a omc and a 302. I was thinking about switching from a two barrel carb to a 4 barrel (switching manafold also). Is there any difference between a marine carb and a regular car one? thanks
  #2
Old July 19th, 2007, 09:17 PM
MikDee's Avatar
MikDee MikDee is offline
Default Re: carb issues
Basically no, But there are a lot of extra outlets, & vacuum lines usually on an auto carb that you have to figure out what to do with, and the choke, and throttle linkage may have a different configuration, that's not matching to the marine application, but maybe adaptable. By the way, is that a 302 Ford motor, or a 305 Chevy motor?
__________________
89'-19' Bayliner Capri Ski boat, with a 125hp Force
My Previous Boats http://smg.photobucket.com/albums/v2...ee/My%20Boats/
My motto - Keep It Simple Stupid
  #3
Old July 19th, 2007, 09:36 PM
thanks, and it is a ford 302
  #4
Old July 19th, 2007, 10:17 PM
MikDee's Avatar
I had one of those it was a 188hp Mecruiser 302-2bbl in a 1974-18' Wellcraft Airslot. I believe it is the Windsor design, not the Cleveland design, and I couldn't find a 4bbl manifold for it at the time, unless I bought new, but I didn't have the money to spend.
__________________
  #5
Old July 20th, 2007, 09:35 AM
imported_John_S imported_John_S is offline
Yes! there is major safety considerations that a marine carb has, but auto does not! Any carb in an I/O must be CG approved. While there is not allot of differences, it is critical to use a marine carb to prevent explosions within the confined space around an I/O. The main difference is fuel bowl venting. All venting must be directed down the barrels of the carb. If you look at a Holley marine vs auto carb, you will notice the prominent J tube vents on the marine version. There are also bushings, attachment place for fuel pump failure vent, accelerator pump seal, and other small changes to prevent/reduce chance of fuel dripping external. There are also non-safety differences, including the reduced vacuum line attachments, such as corrosion protection, and marine is jetted significantly richer than auto.
It is a real threat of explosion, and after the investigation all liability will be dropped in your lap - if you survived! Outside of that, you can get stiff fines from spot inspections on the lake. They probably will make you get towed, vs letting you drive back to ramp. Research through the I/O forum, every year there are numerous discussions on this.
Now back to your mod. I have seen a few posts of Ford 302 upgrading to 4brl. You will get some hp increase, but it isn't allot. You are probably talking only a 2-3mph wot improvement. If you are raw water cooled, and boat in salt or brackish water, finding a cast-iron manifold maybe somewhat difficult. If aluminum, you would need a marine specific (bronze water passages) and don't know of any being produced for the Ford 302.
  #6
Old July 20th, 2007, 01:10 PM
jddenham's Avatar
jddenham jddenham is offline
Send a message via Yahoo to jddenham
Not to mention a 20 - 30% increase in your GPH.
  #7
Old July 20th, 2007, 04:15 PM
Yea, at or near wot gas milage is going to drop. While there are claims that 4brls maybe more efficient when only running on primaries, it is always debatable and generally hard to prove. If you are worried about gas milage, having a good running carb is more important than changing.
  #8
Old July 20th, 2007, 05:32 PM
MikDee's Avatar
Well I should have figured that, I know the fuel pump, distributor, alternator, and starter are marine specific for good reason's, no external spark, or gas vapors allowed, but you would think there would be some way to adapt the carb for marine use.
Yeah, I about gave up trying to find a stock 4bbl manifold, or an aftermarket (non aluminum) for my old 302/188hp Merc. That boat sounded so nice, someone had put long exhaust hoses angled to the outside corners of the transom, and brass outlets, just above the waterline on it. It was mellow, but ate gas by design,,,lol
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
volvo AQ125A carb issues greg578 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 July 16th, 2008 08:51 AM
9.9 evinrude 4 stroke ,carb issues? pontoon chief Johnson & Evinrude Outboards 5 June 23rd, 2008 09:12 AM
Carb issues need help Tadd_P Mercury & Mariner Outboards 1 July 10th, 2007 07:57 PM
suzuki 6 hp carb issues freddyray21 Yamaha & Suzuki Outboards 2 October 11th, 2006 02:51 AM
BF45A with Carb issues socal01 Honda & Tohatsu/Nissan Outboards 4 June 28th, 2006 02:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
