I have an '87 Mercruiser 470 (170HP) with Fresh Water Cooling and have been losing coolant at an alarming rate. I do see that some is coming out of the weep vent (which i assume means that my front cam seal needs replaced), but I am also wondering if I should check to see if my heat exchanger is leaking fresh water into the raw water side (and then discharging it). I am trying to track down my overheating problem and I am currently dismissing the idea of a bad impeller (only because I am also losing coolant). Once the coolant issue is fixed, and the system still overheats, than I guess I will need to look into a new impeller.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
