  #1
Old July 18th, 2007, 08:15 PM
HondaPower HondaPower is offline
Default 1985 50 Mariner 4 Cylinder Thermostat ??
Have looked everywhere on the block, and factory manual does not show one. Can I safely assume it does not have one and therefore I should have water out the telltale as soon as it starts or as soon as the water jacket is filled? Ran for the first time this year, no telltale in barrel or with muffs. Dropped the leg and checked the impeller, (new last year when I bought it) it was like new as was the entire pump housing. Hoping that it is a stuck thermostat, but not holding out alot of hope.
  #2
Old July 18th, 2007, 08:51 PM
Laddies Laddies is offline
Default Re: 1985 50 Mariner 4 Cylinder Thermostat ??
There is no thermostat on that model, first make sure the telltale is not plugged if it'd clear, you might drop the lower unit and fasten a low pressure hose to the engine w/ tube and see if you have water from the telltale. If you don't you may have a peice of the old impeller stuck in a water passage
  #3
Old July 18th, 2007, 10:06 PM
Thanks, will give it a go in the morning, and if stiil no telltale will drop lower leg and hookup a hose to the copper water pipe. Appreciate your response, have done a lot of older small motors but this is a little intimidating. Will post results tomorrow.
  #4
Old July 19th, 2007, 09:49 PM
Back flushed from the fitting on the top of the block back through the leg and then restarted, and got a weak stream out of the telltale. Waited for several minutes and the telltale got stronger, water coming out running on muffs got warm but not really hot so hopefully this little adventure is finished. Going to the lake this weekend for a shake down cruise. I will keep a close eye on it, and if problems develope I will use the trolling motor to get back to the launch. Thanks very much for your response Laddies.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 50 hp Cylinder dropping srussell28 Mercury & Mariner Outboards 3 October 14th, 2006 05:58 PM
1985 20hp Mariner Thermostat michiganmarty Mercury & Mariner Outboards 2 June 16th, 2005 09:31 AM
Thermostat DT-40 1985 jimnmad Yamaha & Suzuki Outboards 2 November 20th, 2004 11:19 PM
1985 40 hp Evinrude Thermostat DO I need it ? Turtlelips Johnson & Evinrude Outboards 2 July 31st, 2004 04:55 PM
thermostat cover plate frozen to cylinder head stilllearning6 Yamaha & Suzuki Outboards 2 September 22nd, 2001 05:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
