Re: Force 125 Choke Blowing Fuses
Use an ohm meter on the side of the solenoid and the terminal with the green wire disconnected. If you have zero ohms, the coil is shorted. I do not know what the actual specifications for resistance are. If you have an enrichment valve, Find the ground and power terminal and do the same.
