  #1
Old July 18th, 2007, 04:41 AM
reelfishin reelfishin is offline
Default Fixing crack in aluminum hull?
I have to fix a small crack in a lapstrake aluminum hull, it's a small split about 3/8" long right at the corner or upper end of a rib. There is no deformation of the metal, just a small crack. I am debating on whether to just drill and epoxy this or to weld it. I am concerned that welding on the open sheet metal sides may warp the side panel?
Someone had tried to repair it with some sort of sealer but it looked like body filler or some sort of resin or epoxy. They didn't clean it so it didn't stick, and they made no attempt to access the inside area either.
I'll have the floor completely out and will be either epoxy coating or using Gluvit on the entire inside below the water line.
The dark areas in the pic around the damage is still some of what ever sealer they had on it, the rest of the area is rough from someone either trying to use heat, or from someone hammering the area to close up the crack.
Here's a pic:
  #2
Old July 18th, 2007, 05:28 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Fixing crack in aluminum hull?
i filled this one with marine JB weld.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 18th, 2007, 12:16 PM
I'm sort of leaning towards just using epoxy, aluminum this thin will most likely warp when heated. The boat's sides are straight now, I don't want to ruin that.
I looked for two years to find one that wasn't dented or pitted, I don't want to make anything worse. I welded a section on my jon boat with good results, but that was along an existing weld. This is mid panel.
I do want to make the exterior look untouched though, so I may indent the area slightly and use the epoxy as filler and feather it out? Right now it looks like there's a slight bulge there from what ever the last owner was trying to do. Theres some charred paint around the edge, but I think someone was trying to either solder the crack or maybe dry some sort of sealer?
The rest of this hull is mint, they have a few rivets covered with silicone, but after removing the silicone, I can't make those rivets leak and none are loose. I have an air powered riveter for aluminum, it's made for airframe repair that does a really nice job on tightening loose rivets too.
I am pretty impressed how this is built, you can tell that these were built to last. I especially like how easy the transom is to replace, other than four pop rivets on the top corner caps, the rest is all screws and bolts, the wood slides right out the top. It took longer to go get the wood than it looks like it will take to install it.
The floor looks almost as easy, plus, no pumped in foam, just cut to fit pieces of what looks like the same foam as those float noodles from Walmart.
  #4
Old July 18th, 2007, 02:43 PM
b.gagnon b.gagnon is offline
That looks more like rotting do to corrosion and a crack.. Locktite makes an Aluminum repair epoxy that the machine shop where I work uses to fix mistakes(big and small) When hardened it holds up with no problem to machining.
  #5
Old July 18th, 2007, 02:48 PM
iwombat's Avatar
iwombat iwombat is offline
I would see what a weld shop would want to fix that. With proper equipment you can weld pop cans.
  #6
Old July 18th, 2007, 04:01 PM
Zero Balance's Avatar
Zero Balance Zero Balance is offline
It can be welded (if done properly) without warping. I would think since both sides are accessable it would only be a minimal charge if welded. Maybe 3 hours tops, sanded and buffed out. Then again if having a two tone repair doesnt bother you then fix it yourself with epoxy or JB weld or something.
  #7
Old July 19th, 2007, 03:19 AM
I can weld it myself if I so choose that route, I have a good water cooled tig machine here. the problem is that even the slightest amount of heat may cause it to belly or warp. If it weren't in such a location, if it were up against a rib or close between two rivets welding it would be simple. The area is no corroded, the dark spot are somesort of sealer that someone used. I found a tube of something called Liquid Steel in the boat, so I assume it's that. What ever it is its tough, but it only adhered where the surface was really roughed up.
The area is ruff because it looks like someone hammered it out or tried to stretch the metal to close up the crack. The only breach is that vertical crack, about 3/8" long and it runs against the strakes, not with them. The whole area in the pic covers about 6".
If I use epoxy, or weld, there will be no two tone repair, it's a painted hull and it's white and far below the water line. This crack it about 3 strakes from the keel on the left side about midway back. It looks like a stress crack to me, or else maybe someone hit something, and the crack developed after the area was straightened? There looks to be some sort of solder around that area too, not melted aluminum, but some sort of solder or added silver metal. Solder will not stick to aluminum, so I was wondering if it was either some sort of sealer or maybe Alumaweld or something similar?
I have used that stuff before with good results, but it's near imposible to use upside down without some real practice. That stuff does adhere very well, I used it to repair a tear in a hull a while back but the heat of the propane torch warped the hull a bit. On that boat I didn't care, it didn't have a straight section on it anyhow. This one needs to be perfect.
  #8
Old July 21st, 2007, 05:38 PM
6228SH 6228SH is offline
I'd weld it,but you've already said you'd rather not-so if it were me,the stuff the machinist mentioned sounds like something I'd look into...
  #9
Old July 21st, 2007, 08:55 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
http://www.alumiweld.com/h2uaw.html which only uses a propane torch which is actually a solder type joint OR get some aluminum epoxy and have at it.
I would find out what caused the crack first. A regular aluminum welder will work and the heat distribution is really not as far or severe as you may think. When you use the gluvit inside you only need to apply it on the rivets and seams..... the entire surface will just waste it.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
fixing crack on bottom of hull MASTER Brian Boat Restoration and Building 13 August 5th, 2007 10:47 PM
Crack in aluminum JimMachinery Boat Restoration and Building 7 July 30th, 2007 04:39 PM
fixing little holes thoughout aluminum boat BLLDOGG Boat Topics and Questions (not engine topics) 5 November 30th, 2006 09:40 PM
Aluminum crack novotm Boat Topics and Questions (not engine topics) 7 April 16th, 2004 08:23 AM
Crack in aluminum on my outboard b.orear Johnson & Evinrude Outboards 2 May 13th, 2003 06:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
