rob.crawford@sympatico.ca
- Jun 24, 2007
- 1
We were out in the boat todayhit some rocks i thiunk.The outdrive kicked out of gear .I put it in neutral tried forward and reverse no luck Just a little clicking sound.Pulled boat of water.When shifter in forward prop will turn both ways with a little noise .The prop and shaft are spinning so its not theprop spinning in the sleeve.I pulled outdrive offWhen i turn the drive shaft the prop doesnt spin.Its a 1986 alpha 1 170 hp any ideas maybe pinion in bottom end?
