I own a 2003 Bayliner 285 with A.C. The A/C condensation drain flows from the drain pan down a flex tube into a housed bilge pump with a float swith. The enclosed bilge pump and swith box is located under the V berth. There is no power to the pump or switch and I can not find where the bilge pump and float power wire originates. I have checked all circuit breakers, the battery A/B breakers and around the battery terminals. Does anyone know where the power wire originates or where the problem might be (in line breaker, etc.)?????
Well, it looks like the resident experts are out to lunch on this one so why don't you just give Bayliner a call @ 877-861-6494. Have your HIN with you - they will ask for it. Very pleasant folks to talk with.
