need advice on engine that been land locked
shipwreck
the engine is 60 hp evinrude
1967 four banger
it has seen water in 2 years
the lower gear oil been changed, it has low compression of on all four cylinders.
and put new plug in the engine runs, new carb float.
The question :
what else should i do to the engine to get ready to get wet?
WillyBWright
Re: need advice on engine that been land locked
Hang it on a boat. ;)
But seriously folks...
You should put in a new water pump impeller
I'd run double oil the first tank, or at least 1.5x
Evinrude Boater
A new water pump is highly recommended when you don't know the condition of the existing pump.
shipwreck
thanks all
and thanks NgtvNrg
good stuff
