nissan9.9 two stroke problems
kola
Hello I'm new to this forum
Ihave this nissan9.9 that I use as auxiliary power on a small sailboat.
I have these 2 separate problems.
1. One of the 4 bolts holding the 'foot' of the motor has seized, so I can't replace the impeller.(impeller is still working well for now)
2. It starts ok, at idling speed works soothly up to 1/3 of the trottle but stalls in mid-trottle. At full trottle, it works but very erratically.
This problem arised suddenly, tried new sparkplugs and fuel oil mixture is ok.
Any advice please?
thanks
TOHATSU GURU
Re: nissan9.9 two stroke problems
Application of heat to the area surrounding the bolt and have your carburetor cleaned.
kola
Thanks for the advice.
I was also thinking of adding an extra fuel filter across the line from the tank to the motor.
Is this a good idea, or it would affect the flow of the fuel?
