  #1
Old July 16th, 2007, 09:54 PM
25 Pursuit of Happiness 25 Pursuit of Happiness is offline
Default 150 Evinrude starter
Hello, I'm new to the site and will appreciate your help. I have a 97 150 Evinrude Ficht with newer powerheads. The starter is turning but does not turn the motor, I pulled the starter out thinking it was like a car starter with a bendix, but it doesn't seem to be...it just turns. How does it engage the flywheel on the motor? Is there a clutch there? Am I missing something here? What part do I need to buy? Thanks for any advice.
  #2
Old July 16th, 2007, 10:07 PM
bhile's Avatar
bhile bhile is offline
Default Re: 150 Evinrude starter
The bendix engages the flywheel from centrifigal force. Clean and lightly lube the shaft it rides on. If it is going all the way up and engaging the flywheel but still not turning it, then it needs to be replaced. Also be sure all battery connections are clean and tight and the battery is in good condition..
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old July 16th, 2007, 10:10 PM
Fl_Richard Fl_Richard is offline
Master Chief Petty Officer
Up inside the flywheel cavity is the real bendix. The starter is removable seperately if it's like my 95
  #4
Old July 16th, 2007, 10:19 PM
I checked the cables and actually ran jumper cables from a good battery to the motor (including making sure the starter was properly grounded.) I have twin outboards on the boat and the other motor starts right up. I have the starter in my hand...well I just set it on the table, and the gear cannot slide more than a 1/16" of an inch, unless the whole shaft slides from inside the motor, and it doesn't seem to move in or out. After I pulled the starter I tested it and it spins OK, but certainly does not eject. Any ideas?If the bendix is inside the flywheel cavity, how does it engage the teeth of the flywheel? There is a gear with 11 teeth at the end of the starter.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Old Evinrude Starter zachmoser Johnson & Evinrude Outboards 1 November 7th, 2005 02:37 AM
Evinrude Starter Randy Britton Johnson & Evinrude Outboards 5 September 8th, 2005 05:03 AM
Evinrude Starter SkipMoss Johnson & Evinrude Outboards 3 July 18th, 2004 01:53 PM
Evinrude Starter doesn't pop up shade788 Johnson & Evinrude Outboards 13 August 4th, 2002 08:06 PM
Starter for 69 evinrude 18 hp Bob Gill Johnson & Evinrude Outboards 0 September 5th, 2001 01:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
