  #1
Old July 16th, 2007, 12:44 AM
jhj141 jhj141 is offline
Default 1972 85hp Evinrude stalling
I have A '72 85HP Evinrude that's starting to drive me nuts. Motor was running fine and I started having problems with it bogging out at half throttle and above. Checked the fuel pump and filter and found a little 'gunk'.
Cleaned out the lines, replaced the pump and rebuilt the carbs.
After this, it started up with no problem, but put it in gear and give some gas and it stalls out. Adjusted the idle screws and it ran better and would take more throttle but still bogs out and stalls. It seams like it would take all the gas you want to give it in neutral, but for obvious reasons I'm no going to try it. The strange thing is it will take all the throttle you care to give it in reverse.
Local 'mechanic' told me to bump the choke when it starts to bog out and stall, but it only accelerated the motor stalling.
I'm out of ideas, and hoping someone might point me in the right direction. I ordered a manual, but it will be a while before it gets to me.
  #2
Old July 16th, 2007, 02:05 AM
bogggar1 bogggar1 is offline
Cool Re: 1972 85hp Evinrude stalling
Did u adjust the throttle cable or anything before trying to make it run better???
__________________
***FISH ON***
  #3
Old July 16th, 2007, 02:17 AM
_brad_'s Avatar
_brad_ _brad_ is offline
Send a message via ICQ to _brad_
Default Re: 1972 85hp Evinrude stalling
I would check your spark on all cylinders AND check to make sure your plugs aren't fouling out. I had a similar issue on my 1977 70 HP rude; it would bog down past half throttle. After doing what you basically just did it ended up being a fouled bottom cylinder plug. Changed plug and ran great.
__________________
Brad
1975 Starcraft Super Sport w/1977 70 HP Evinrude
  #4
Old July 16th, 2007, 07:02 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
common problem when the carbs, are not properly done. did you use the special screwdriver and remove the high speeds jets, that are hidden way down in the hole of the drain plug on the front of the carb? these have to be removed and the area clean of any varnish, to shiney clean. the tool can be made with a quality screwdriver. i used my belt sander to narrow it down to fit. picture is compliments of FR.
http://i155.photobucket.com/albums/s...g?t=1177353186
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old July 16th, 2007, 12:28 PM
Quote:
Yes, the travel on the throttle cable is correct.
  #6
Old July 16th, 2007, 12:31 PM
Quote:
I have spark on all cylinders, though the plugs are damp. That may be from adjusting the idle screws. I'm going to change out the plugs just to be sure.
  #7
Old July 16th, 2007, 12:35 PM
Concerning the drain hole, are you referring the the two small bolts that serve as plugs on either side of the bottom of the bowl?
I am pretty sure I had removed and cleaned every part, but you never know, I may have missed something.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1972 Evinrude 85hp Starflite jjoediv Johnson & Evinrude Outboards 8 May 14th, 2006 03:49 AM
1972 85hp evinrude won't start rundy1981 Johnson & Evinrude Outboards 11 February 12th, 2006 12:03 PM
1972 85hp Evinrude parts Bobk321 Johnson & Evinrude Outboards 3 March 29th, 2005 02:41 AM
Need to know oil mix to my 1972 Evinrude 85hp pillatzki Johnson & Evinrude Outboards 7 August 5th, 2003 09:12 PM
1972 Evinrude 85hp WeBull Johnson & Evinrude Outboards 1 July 31st, 2003 12:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
