Is it possible to use a 1978 lower unit with a 1985 motor? Johnson 150GT V6
A Albright Recruit Joined Jun 21, 2007 Messages 1 Jun 21, 2007 #1 Is it possible to use a 1978 lower unit with a 1985 motor? Johnson 150GT V6
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jun 22, 2007 #2 Re: Johnson lower unit interchangeable? i sent a message to the guru. you aren't being ignored.
G Gassman Recruit Joined Oct 26, 2007 Messages 3 Nov 18, 2007 #3 Re: Johnson lower unit interchangeable? I have a similar question does anyone know if a 1974 Johnson 50hp lower unit will work on my 1984 50hp johnson? thanks Ron
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Nov 18, 2007 #4 Re: Johnson lower unit interchangeable? gassman no. there was a change from shift assist to mechanical shift, around 1978.
G Gassman Recruit Joined Oct 26, 2007 Messages 3 Nov 20, 2007 #5 Re: Johnson lower unit interchangeable? Thanks for the reply, anyone know if a 1981 60hp gear box will work on my 1984 50 hp Johnson? Shaft looks the same, but no anode on the 60hp case, Thanks Again Ron
