Re: Help with ficht 225 evinrude!
It is time consuming trying to find an intermittent problem.
You will need a service manual and wiring diagram to remove the correct EMM connector and using an ohmmeter on high ohms, check from the correct socket to ground. Wiggle and bend the harness and see if the resistance changes at all. In extreme cases, you split the wiring harness and trace the whole lenght of the affected wires.
