  #1
Old July 15th, 2007, 06:22 PM
cambis9 cambis9 is offline
Default mariner 75 engine problem
hi everyone i am new to the boating scene and would like some help please.
i purchased a shetland family four and it was fitted with a mariner 75 2 stroke outboard, we have used her twice. however i let my son and friends borrow it and he phoned to say that the engine was running then stalling then running again. so he came back to shore and said a lot of white smoke was coming from it. does this mean the head gasket could be at fault and is this an expensive repair i think he had too many on board.
cambis9
  #2
Old July 15th, 2007, 10:20 PM
emckelvy emckelvy is offline
Default Re: mariner 75 engine problem
Sounds like the white smoke could be steam, from overheating. Hopefully they didn't run it too many times or it's quite bad for the engine.
Best thing you could do now is to try and start it; see if it's got any water flow out the telltale; and feel the exhaust manifold cover to see if it's getting hot really fast. If it is, you don't have enough (if any) cooling water flowing and shouldn't run the motor any more until you get to the bottom of the problem.
In that case, time to remove the lower unit and check/renew the pump. If the impeller is disintegrated, you'll want to check the water pipe for pieces of impeller (run some stiff wire up the pipe to check for obstructions) and perhaps check flow thru the powerhead by hooking up a source of water to the copper water supply pipe (adapt from the garden hose to the pipe).
Unless your Mariner is a Yamaha-derived motor, it has no head gasket. That back plate is just a block cover, underneath is the big water passage around the cylinders.
If you did overheat, it fried the block cover gasket, so watch out for external leakage; it didn't do the exhaust manifold gaskets any good either. If they leak to the inside, you can get water in the motor (it'll show up on the spark plugs).
If the motor overheated badly, it bodes poorly for the rings & pistons and you should have a compression check or leakdown check done before putting a lot of money into other repairs.
BTW it would help to know the serial # of your motor, that'll pin down the year and mfr.
HTH & G'luck.........ed
  #3
Old July 16th, 2007, 03:02 PM
thanks for getting back to me i will check waterflow the serial no is 9463216 thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner engine manual jsh159 Mercury & Mariner Outboards 0 April 5th, 2007 01:54 PM
45 hp Mariner, oil under engine cover perdidojoe Mercury & Mariner Outboards 0 April 22nd, 2004 04:34 AM
Mariner engine value Dakota Fox Non-Repair Outboard Discussions 1 September 17th, 2003 05:16 AM
older Mariner engine Richard 1968 Mercury & Mariner Outboards 0 July 20th, 2003 06:04 PM
1985 Mariner 50hp 4cyl - engine problem David Cordry Sr. Mercury & Mariner Outboards 2 April 14th, 2003 12:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
