Hey
I have purchased a 96 tiller drive, pull start, 3 cyl, with oil tank on motor
the motor is super clean and was told low hours, it shows little wear
After test running in a barrel at purchase it did smoke allot but calmed down after a few mins, and had been foggged at storage. I took her out for the first time on the lake for a real test, and she cranks right up and runs fairly smoothe at idle, at low speeds she purrs and runs fine, but when you throttle her down, she will go for a min or two then just die, pull the rope and she cranks on first pull everytime, I replaced the spark plugs with new ones, and tried again to same effect, do you think the fuel filter could cause a problem like this??
it seems to be a fuel issue but im not sure HELP please thanks in advance
ncbugnut
ncbugnut
