Re: chrysler 45
Don't have a diagram but yellow wire goes from wire loom terminal on exhaust port to neutral interlock switch. other yellow goes from other side of switch to the small terminal on solenoid. Some solenoids have a separate black ground some do not. Battery cable to front or front top of solenoid, Starter cable from other side of solenoid to terminal on bottom side of starter motor. Yellow in cable connects to S (Start) terminal on switch, Red to B (battery) If you have magneto ignition, blue and white wires go to the M terminals--either direction is ok. This shorts out magnetos to stop engine with switch off. White is also tachometer signal. Not sure about points and coil ignition but blue is usually power to points from I (ignition) terminal on switch.
