  #1
Old July 15th, 2007, 12:07 PM
kevin boothe kevin boothe is offline
Default cooling for a Mercury 150 hp Black Max
What is the usual time after start up for water to be discharged from this motor? Would having it at fast idle speed up the cooling or is there a thermostat controlling the cooling?
  #2
Old July 15th, 2007, 09:53 PM
fishingdan fishingdan is offline
Default Re: cooling for a Mercury 150 hp Black Max
What year is the engine?
Do a search. You'll find several discussions on the cooling system for these engines.
It is hard to answer your question. I know on my 1982 150, I get a dribble (barely) after about 15 seconds. On my engine, water only gets to the tell-tale when the t-stats open. It will get a weak stream after running hard, but then it will reduce to a dribble again after idling a bit.
In general, I would say 15 seconds is a good number.
  #3
Old July 16th, 2007, 11:09 AM
wilde1j wilde1j is offline
My '95 150's took about 30 to 60 seconds to have water come out of the telltale port. This really doesn't tell much, other than the water pump is working (sort of), so I wouldn't get my shorts twisted in any case. My Merc discharged from the end of the cooling cycle and the water was normally pretty hot coming out.
__________________
Jim
  #4
Old July 16th, 2007, 08:50 PM
Jim My 150 is a 1992 I get a good stream after about 30 -45 seconds and runs in the middle of the temp gauge on a 180 procraft
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Black Max 1750 cooling ?????/ Duxbass Mercury & Mariner Outboards 1 June 8th, 2006 11:51 AM
Are these props the same (Mercury Black Max vs Quicksilver Black Diamond)? BRG25 Boat Topics and Questions (not engine topics) 8 August 17th, 2005 07:05 AM
175 mercury Black max delta breeze Mercury & Mariner Outboards 4 August 26th, 2004 12:20 PM
Black Max 200hp cooling problems please help Thecol Mercury & Mariner Outboards 11 August 13th, 2003 03:47 PM
What spark plug for my Mercury 1993 150 hp Mercury black max profish Mercury & Mariner Outboards 4 April 23rd, 2003 06:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
