  #1
Old July 14th, 2007, 03:42 AM
bigmarc66's Avatar
bigmarc66 bigmarc66 is offline
Default 15 HP Evinrude Starting Question
I just bought a 15 hp evinrude with the low speed fuel mix adjustment knob. The guy told me that it had an issue first starting, he told me to take an eye drop and drop a few drops of gas into the mixture adjustment port. This puts gas right into the carb and it gives it something to start with. It works like a charm, the motor fires right up. Does anyone know a solution to the eye dropper and a fix for this, or cause for this?
  #2
Old July 14th, 2007, 04:54 AM
iwombat's Avatar
iwombat iwombat is offline
Default Re: 15 HP Evinrude Starting Question
What year? There's a few carbs we could be dealing with here. Still, you shouldn't be able to get anything in the idle mixture orifice. It ought to be sealed up with the adjustment screw.
The cause is your choke/primer not working properly.
  #3
Old July 14th, 2007, 06:47 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
agree, what year, model #?
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old July 14th, 2007, 08:11 AM
wbeaton's Avatar
wbeaton wbeaton is offline
Yeah. Check the operation of the choke/primer and/or rebuild the carb.
  #5
Old July 15th, 2007, 02:25 AM
bigmarc66's Avatar
Thanks for the feedback, it is a E15 RCLS, I believe it to be a 1980. So you guys think that the choke is not working correctly. I will have to look at the choke. Can anyone explain what to look for and explain how it might be messed up. The carb was rebuilt last year. Thanks
  #6
Old July 15th, 2007, 05:38 AM
i believe if you recheck the model # you will find it is E15RCIS makes it and 1981, could not find L. heres is the correct manual http://www.outboardbooks.com/index.c...81&ID=1049 48
i you go here and follow prompts, you can view engine diagrams, http://www.evinrude.com/en-US/Accessories/Literature/
your problem, you carb, has a choke plate,(butterfly) that opens and closes, i the closed position it blocks the front of the carb, cutting down the amount of air into the carb. if it is not closing all the way, the fuel is not enrichened, it should close all the way, and open to horizonal when deactivated.
__________________
FLORIDA GATORS
TEBOW Country
  #7
Old July 15th, 2007, 09:26 AM
wbeaton's Avatar
If the carb was rebuilt last year and never ran right then I'd guess it either wasn't set properly or it wasn't thoroughly cleaned.
  #8
Old July 15th, 2007, 10:46 AM
bigmarc66's Avatar
Would the choke affect the fuel in the carbuerator though? Since the guy told me to put gas into the carb, do you think that is more of a primer and fuel problem or could the choke conceivably be the entire problem? Thanks
  #9
Old July 15th, 2007, 10:52 AM
when you put the fuel in the carb, you are essentually chokeing it. you are increasing the fuel/air mixture. that's the purpose of the choke cutting off air flow, to increase fuel to air. if the choke is not closing, the motor is getting too much air on the cold start.
__________________
FLORIDA GATORS
TEBOW Country
  #10
Old July 15th, 2007, 12:45 PM
wbeaton's Avatar
Adding extra fuel to start the motor when the butterfly is open is the same principle as priming.
  #11
Old July 15th, 2007, 02:29 PM
bigmarc66's Avatar
thanks for the feedback guys, I am going down to look it over today after work. Another quick question is about the throttle being sticky and tight to turn. To get the motor all the way revved up you really gotta jerk it and it will not come back to neutral unless you jerk the throttle down so that it clears the shifter plate. Any advice? it looks like there are grease fittings but they do not grease up with my gun.
  #12
Old July 15th, 2007, 03:21 PM
mikesea mikesea is offline
As for the choke,there is a slot in the pull to choke lever,there is also a lever that should fall into the slot from the carb,sometimes the choke part falls out,especially if the plastic choke arm broke or bent,it may also be upside down not allowing full choke.As for the throttle,on the port side of the engine you will find a linkage arm that connects the throttle to carb and the timing base undr the flywheel.This linkage is held in place buy a couple screws ans the connections to the for mentioned.that linkage arm sits in a slot that has a gear on it,and that gear piece very often gets gunky from old grease ,the reason it wont take grease my be the problem,to fix it properly,you should remove the moving parts and gear from the alum.housing and clean it throughly and grease with a waterprof grease,keep it greased often ,you may also find the problem to be in the handle as well,the same problem exists,there are plastic bushings that get salt,or dirt build up and thus strangles the parts that should move with ease,if you let it go too long it will get worse with end result being bent,shafts stripped gears,.Good luck
  #13
Old July 15th, 2007, 07:51 PM
bigmarc66's Avatar
The throttle is very tough under the fly wheel. The handle is very well lubed, but under the flywheel wear the throttle turns is very tough. I have to jerk it pretty hard to kick it into full throttle. There is a problem when this happens. On the Pull start there is a red latch that latches so that you cannot pull it. When the latch is not latched i can pull the pullstart, BUT, the throttle will not open up all the way. I eventually got the throttle to open up all the way, only to find out that by getting the throttle to open up all the way only latched the pullstart so i couldnt start the motor again until i took off the cover and manually moved the latch. Any suggestions? it looks like the red latch is rubbing on something and not functioning right?
  #14
Old July 15th, 2007, 09:24 PM
wbeaton's Avatar
If the tight throttle truly exists under the flywheel and not the throttle linkage then the armature bearing is likely worn out. You'd have to remove the magneto to get to it.
That red tab on the starter is there so you can't pull start in gear or with the throttle too far advanced. Where ever the tiller grip stops is where you should be starting the motor - not at WOT.
  #15
Old July 16th, 2007, 04:28 PM
Water Strider Water Strider is offline
I have an 82.
The design prevents you from going full throttle in nuetal. Without the load of being in gear, you could ruin the engine. You wouldn't want to run full throttle in a test barrel anyway, you'll throw the water out and either drown the engine or suck air in the impeller. If you have been forcing it to full throttle in nuetral, then you probably buggered something up on the "safety" mechanism.
As mentioned, it's also designed so you can't pull start in gear, you have to go back to nuetral. Then all the plastic linkages will fall in line for you to pull.
Sounds like somebody did a bad carb rebuild to me.
  #16
Old July 16th, 2007, 05:45 PM
bigmarc66's Avatar
Water Strider I understand what you're saying, but what happens is that latch gets stuck and does not release unless i manually do it. I dont know if its meant to be like that. i.e I accidentally tried to start it in gear, pull wouldnt pull so i took it out of gear and put the throttle all the way down but it still wouldnt pull until i undid the latch, is that how its suppopsed to be or is it supposed to release. I had a 2000 nissan that if i pulled in gear wouldnt pull but once i pulled it out of gear it pulled fine. This doesnt. Is that normal or should it release?
I have looked over the choke and it seems to be in correct working order, it opens the butterfly when its open, yet it still doesnt function properly. I manually put the choke all the way down and tried to crank it, but still didnt fire with out a few drops.
As for the throttle, it definetly seems to be tight under the fly wheel, if i dont use it for a day then the next day with the motor off, i manually have to move the throttle linkage under the flywheel to WOT before it will kick in by using the handle. What kind of a job is it to get to the armature bearing? Im good with my hands, and have worked on motors just not outboards, is it possible? Thanks
  #17
Old July 16th, 2007, 06:07 PM
wbeaton's Avatar
I think you need to revisit the carb. He may have "cleaned" the carb, but I doubt he actually rebuilt it. If it was performing properly you wouldn't need to add extra gas to start it. Where is the low speed jet set? It should be set 1-1.5 turns to the right from lightly seated.
The armature bearing isn't too hard or expensive to replace. Pop off the flywheel and unscrew the armature from the retaining ring. The armature bearing is a plastic piece that looks like a ring and is wrapped around the edges of the armature support ring. Check out the parts diagram for your motor at BRP. It is listed as part #9 under magneto (0322435).
http://epc.brp.com/default.aspx?brands=ej&lang=E
Just make sure you torque the flywheel nut to the proper spec when you put it back together.
  #18
Old July 16th, 2007, 09:00 PM
Xcusme Xcusme is offline
Quote:
Originally Posted by wbeaton View Post
.... Where is the low speed jet set? It should be set 1-1.5 turns to the right from lightly seated.
Well...that's almost right...it's 1-1.5 turns counter clockwise (left) from lightly seated. Otherwise, accurate suggestions.
  #19
Old July 21st, 2007, 02:20 AM
When I put mine back in nuetral and turn the throttle all the way down, then the linkages fall back in place and allow the start assembly to engage the fly wheel again. It resets everything.
If it's not doing that, then I would look for broken parts or would suggest some areas are in need of some lube.
  #20
Old July 21st, 2007, 02:56 PM
Im willing to be if you fix the problem under the flywheel,things will get better,what is happining is the timing is all screwed up,that is what the piece under the flywheel is all about,more than likely a simple remove,degrease and lube with a silicon spray will do the trick
  #21
Old July 21st, 2007, 06:55 PM
Rick. Rick. is offline
Just to clarify things a little. I own an 82 15 HP. The motor will start in forward, neutral and perhaps reverse(I can't remember trying it in reverse) The only thing is the motor will not start in gear if the throttle is turned up too high. That's when the safety tab on the pull start stops the starter from being pulled. When you turn the throttle back to idle everything should free up so it definitely sounds as though you need to do some cleaning to free things up. Hope this helps. Rick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starting question Mayfly05 Johnson & Evinrude Outboards 3 May 8th, 2007 11:30 AM
98 Johnson 115 SPL Starting question GatorMike Johnson & Evinrude Outboards 9 March 22nd, 2007 11:25 PM
starting question texsun Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 20th, 2005 07:06 AM
Starting question Big Ears Mercury & Mariner Outboards 2 February 19th, 2005 11:31 AM
Starting question sandmanmike1 Johnson & Evinrude Outboards 1 July 23rd, 2003 02:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
