  #1
Old July 13th, 2007, 11:04 PM
aman69 aman69 is offline
Default 2007 Yamaha F20ESH knocking at 5500rpm
Hi to All,
I have purchased 2007, Yamaha F20ESH a month ago. It is 20hp, 4 stroke, short shaft, electric starter. S# 6AHKS100…... I also purchased a tachometer/hour combo meter p/n-ENG-METER-4C-02.
After braking in (1hr. at 2000RPM and 3.5hr. at 3000RPM), I have increased speed to around 5500 RPM and got knocking coming from upper part of motor, apparently close to rear-left. It sounds like- DING, DING….two three times p/second, non-stopping. If speed is increased the DINGING frequency also increases. If speed is reduced below 5500 DINGING disappears. There is no DINGING in neutral at any RPM, and motor runs very quiet below 5500 RPM.
Yamaha Customer Service told me that it is abnormal, and no any kind of knocking or noisy different from working engine sound should be heard. Overrev protection does not create any sound, and F20ESH engine has no alarm. They advised to see Yamaha dealer.
I was running the boat with dealer’s mechanic, today. He confirmed the DINGING but didn’t know what it is. He checked spark plugs (normal), and told me to run motor for remaining 6 hours out of 10 braking in hours. He almost told me that if something brake than he would know what it is. If dinging continue he will run test with test prop. Well,.. I was not happy with that conclusion.
Does any one have the same engine and what is your experience at 5500 rpm? Any similar DINGING? It is my first boat, and first outboard. What should I do? Thank you for advice in advance.
  #2
Old July 22nd, 2007, 10:04 AM
Default Re: 2007 Yamaha F20ESH knocking at 5500rpm
This is additional information to my original question.
It might sound fanny but after 5.5 hours of braking in the type of noisy has changed. It is clear knocking/tapping now, instead of dinging before. The knocking starts at around 5000 rpm, with frequency about once per second, and increases with rpm up to full throttle. At full throttle it sounds like a military drum. No knocking in neutral up to full throttle. Dealer advised to run motor to the end of braking in period, 10 hours, and than call him back. Thanks for advice in advance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2007 Mariah SX19 vs 2007 Stingray 195LR dshack Boat Topics and Questions (not engine topics) 2 April 10th, 2007 11:11 PM
2007 9.9 yamaha to 15hp conversion edzzed Non-Repair Outboard Discussions 8 February 14th, 2007 01:56 PM
2007 yamaha 9.9 2 stroke edzzed Yamaha & Suzuki Outboards 2 February 12th, 2007 11:30 AM
Yamaha 115hp EFI - 2005 vs. 2007 Bionic Man Non-Repair Outboard Discussions 3 January 26th, 2007 11:08 AM
no compression 1 cyl. still runs 5500rpm dcolpitts Johnson & Evinrude Outboards 7 September 27th, 2004 03:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
