87 Force 50 half power
skibug
Re: 87 Force 50 half power
Need a little more info about the problem to help. Did this just start happening? Any changes done to motor, like prop change etc... Just need a little more info about the problem to try and help.
koolcountry
Just bought boat. I did take and adjust cables got a little more power. Also noticed the bottom coil has a crack in the bottom of it. Dale
roscoe
Check for spark and compression on both cylinders.
This is why an on water test, compression test, and spark test should have been done before you made the purchase.
Not trying to put you down, just trying to educate the other readers that look at this post.
Get back to us with the results.
