Fishin with buds
- Apr 13, 2007
- 31
is staring you in the face and is concentrated around your head gasket?
I have a Evinrude 175 1993 and went to change the plugs and noticed there is about 1/16" of salt caked around my starboard side cylinder head, concentrated on the head gasket, all the way around, anywhere from 1/4" to 1/2" wide. the other side is perfect, no rust or salt. so now i am thinking i have a blown head gasket on one side which is fowling my starboard side and causing the extreme misfire and poor running.
anyone have in thoughts on this????
Long version:
Evinrude 175 1993, just ran an entire tank of mexico gas through the engine, no problems, this is all off US pump gas. however, ran the tank dry on Mex gas for the first time, so maybe a bunch of crud got picked up and put in the engine...?
took out the boat over the weekend, ran 4000rpm for about 20 minutes, four guys , no issues. then it felt like i hit something the engine misfired so bad. so i stopped, checked it out, no issues, tried to turn it back on and that is when it started to get interesting. i have never seen anything misfire so bad in my life and i thought my engine was going to shake off my transom. after trying for a while, thought i might have some bad gas, or maybe my fuel/water seperator was full so i pulled it off and drained it and put it back on. took about 1 hour to get started, then it ran, but had some moments of worry when it misfired and the rpm's lowered a lot, then it would pick itself back up and run perfect. fished 6 hours, ran in, no problems.
next day, same thing, ran good, took a dump after about 20 min, hard starting extream misfiring, ran fine all the way home???
so i was thinking fuel contamination and was going to do new plugs, new filter/water seperator and run some iso-heet to make sure.
went to change the plugs and noticed there is about 1/16" of salt caked around my starboard side cylinder head, all the way around, anywhere from 1/4" to 1/2" wide. the other side is perfect, no rust or salt. so now i am thinking i have a blown head gasket on one side which is fowling my starboard side and causing the extream misfire and poor running.
next step is to check compression one side Vs. the other. but is this just an obviously blown head gasket? if i were to change one side, should the other side be changed for good measure?
Long version:
