Re: 90 hp Evinrude loses then regains power.
Welcome!!!!!!! I have had a very simulare problem witha 1994 120hp Evinrude, all the guy's tried to help and for the most part, they did. Just one factor was over looked and never brought up. I was having fit's over this issue, went thru a lot of extra work and I am hoping I figured it out today. The impulse tube from the crankcase to the fuel pump is metered by a "impulse limiter" fitting. IF this fitting is clogged with carbon (which I have not pulled mine yet but explains all my poblems) it will not send enough impulse (vacume/pressure) to the fuel/VRO pump to operate it properly at higher RPM. This has drove me crazy and I am hoping this is my problem and I hope this helps you, if your impulse line is connected to a fitting on your crankcase that has a blue colored ring around it, remove it, clean it from any carbon deposits and or replace it. I am getting ready to do the same, if it fixes it, I will post it or if you want, I will send a PM. I have sveral posts under my name, SawBum, ck them out and see if our problems are close.
__________________
1994 Evinrude 120
E120TLERC
18.5 Bay Master
