Have been battling problem for a couple of weeks. Motor runs well in driveway on muffs, but put it in the water and can not get the boat to run much past idle. Boat ran ok when I boat her used. It is on a 20' Pursuit WA. Was never able to get her above 4600 RPMS at about 35-37mph. So far have done the following:
changed plugs and wires
fuel water seperator
removed carbs, cleaned and kits
compression 90psi on left bank and 75-80psi on right bank
changed most fuel lines
dismantle fuel pumps and cleaned
coils ok
spark on each cylinder
I'm running out ideas, do have a manual and was thinking of changing head gaskets due to lower compression on bank and getting new fuel pumps, as I was told that once you take them apart they are now no good.
HELP Please.
Mario
coils ok
HELP Please.
Mario
