Hello, I have a 1989 Bass Tracker boat with a 35hp 2-stroke Mercury OB that bears the decal "oil injected". However, the oil unit inside the boat says "autoblend". Recently, I have noticed excessive blue exhaust smoke and rough idle accompanied by the occational dropped cylinder / fouled spark plug. WOT she runs fine.
Based on what I have been told about these autoblend systems, it sounds like mine has started to fail and I should remove it and just pre-mix. That's not a problem; but I need to know what fuel/oil mix to use in this engine.
Are these 50:1 or 100:1 engines?
