Devil_Inside
- Jun 17, 2007
- 76
Hi everybody! Few weeks ago I bought an 18' Grady White with a 1983 Johnson 6o hp outboard. The boat was very cheap and needed some work done, so I've spend the past 10 days working on it, and today was supposed to be the BIG day - first time on the water with her.
When I bought the boat I knew that it will need a lot of work, but for my surprise the engine was working very good. I replaced the spark plugs, cleaned the carburetors, replaced the gear oil and adjusted the throttle. I always ran the engine with the "water ears" on and everything seemed to be fine. So today I filled the tanks and ran the engine for one last time in my driveway just to make sure that everything was fine - and it was!
So here comes the bad part - I went to the lake and launched the boat; started the engine and I couldn't get it to idle... For my surprise the engine would die in less than a minute even with the choke all the way up.. I fought with it for and hour and finally gave up. Went back home, put the water ears on and the engine ran just fine! After that I took and empty garbage can which I filled with water and submerged the engine, but same thing happened - ran like cr*p and wouldn't idle... WHY IT DOESN'T WANT TO WORK IN THE WATER?!?
