searay rob
Thread starter- Joined
- Jun 16, 2007
- 7
I have a 1987 Sea ray Seville 19cc with a 3.0l engine and a alpha1 outdrive. Can anybody help me adjust the switch on top of the motor that makes the engine cut out to shift into neutral. The switch works, If I push the switch with my finger it cuts the engine out. When I shift into neutral I don't think it is working correctly, I have to kinda push and pull the shifter and sometimes it goes to far into reverse. Seems like it has pressure on it from the outdrive.
I am always able to get it into neutral but I don't want to mess up the throttle or cable by having to push on it to hard. I did check the lower shift cable and it is good and working properly. Thank for your time, Rob
