brandonvarnell
- Jun 16, 2007
- 6
Hi, I am having problems with my engine. It runs great on the ears. When I put it in the water, it will idle great and rev up just fine, but when the prop is engaged and it is under a load it will not get up to full throttle. The RPMs increase until about half throttle and then no more after that. It doesn't bog down, it simply doesn't rev any higher. It has no problem trolling through the water at low speeds. I have replaced the fuel lines, gas tank, rebuilt the carbs and changed the spark plugs. At this point I dont know what else it could be. Any advice will be appreciated.
