  #1
Old July 9th, 2007, 07:23 PM
wishin2bfishing wishin2bfishing is offline
Default scratch'n my head 87-89 mercury 40
ok i just got a lowes 16ft falco with a 1987-89 mercury 40 oil injected 35 boats great, motor i havent a clue trying to get to know the motor without spending a load for probly a simple ? ok heres the deal it wont start it will if i shoot starter fulid in it but wont stay running i have replace the old primer and i replaced the fuel tank if it says on the side of motor oil injected do i still mix the gas/oil or is there a oil res/tank i dont see one i have tried the mix 50:1 but still no luck i took the fuel filter off blew it out so i think its ok i have only one boat dealer/service in town they told me it would be at least 300 or more to look at it is there anywhere on the internet that i can get some info on my motor the serial # on the side of the the motor is ob299060 HELP .....james
  #2
Old July 9th, 2007, 07:27 PM
Tadd_P Tadd_P is offline
Default Re: scratch'n my head 87-89 mercury 40
ok for starters never ever use starting fluid on a 2 stroke engine. You will break the oil down in the gas and very bad things can happen to your motor. Second, you dont have to mix your gas as that is what the oil injector is there for unless it has quit working. And third my guess about your troubles is that your fuel pump has went out try looking into that.
  #3
Old July 9th, 2007, 07:36 PM
ok can do on the starter fluid its a no no can u give me a hint where the oil should go i can see no tank for it no place to put it up under the cowl will it be on the outside of the cowl ? please forgive me for the stupidity i show is there a web site that can give me a veiw of my engine
  #4
Old July 9th, 2007, 08:02 PM
not real sure about the website but you might be able to find the oil injector inside of the battery compartment. Just follow any lines coming out of the motor other than the fuel line and one should run to a small white tank somewhat looking like what you would fill the washer fluid in your car just smaller. Ive read on some other peoples problems and it does sound like a fuel pump or pump diaphram. It could be dirty carbs too man. Look into to that and i hope all of your problems are solved.
  #5
Old July 9th, 2007, 08:39 PM
TADD u rock the pump was shot not pumpin the fuel but i still cant find the oil tank i looked all over the place no tubes the only tube i seen was just behind the carb's butterfly valve less than inch n 1/2 from the front of the carb intake the tube was about 3 inches long went to nothing kinda looks cut or dry rot i guess im gonna get a manual in the morning and a new fuel pump if i cant see anything for a tank of oil does this mean the previous owner just did a ratio instead of oil injected (is that even posible?)
  #6
Old December 13th, 2008, 03:33 AM
pete007 pete007 is offline
Look into your dry rot stuff there's gotta be a oil resevoir there somewheres.............
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Question about Mercury V6 head casting numbers dusky Mercury & Mariner Outboards 0 February 3rd, 2007 10:33 AM
Mercury 4cyl. w/ aluminum head? fletch44 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 18th, 2003 05:54 PM
Head Gasket at a Mercury Dealer? turtle1173 Force & Chrysler Outboards 2 August 14th, 2003 04:20 PM
In over my head? Mercury question.. C17LoadSmasher Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 March 5th, 2003 06:24 AM
Mercury Inline 6 115 HP Whole in head above Piston #1 Bry21317 Mercury & Mariner Outboards 4 April 25th, 2002 11:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
