Re: 1971 50 HP Evinrude fuel mix
i have the same engine. 50/1 picked it up for $150, will get it's first run this weekend. i cleaned & rebuild the carbs, and did the impeller. you know it is hydroelectic shift, and to use only Premium Blend type C oil in the lower unit.
