Evinrude 30 shifting trouble
Recently purchased a used pontoon boat equipped with a 1984 Evinrude 30, model #E30ECRR and OMC single-lever controller. Then engine runs like a champ, but if the controller is adjusted to shift into forward, it won't throw far enough to shift into reverse and vice-versa. The lever moves fine through its range, and the gear teeth inside the control box appear to be in proper alignment and serviceable condition.
Right now, I have it adjusted to shift into forward, and whenever I need to reverse, I just use a mop handle to click it into gear.
It appears there is about 1/4 to 3/8-inch play in the cable. The shift lever appears to have a lot of play in it too, but when the tranny clicks into gear the shift is positive and it stays in gear.
Suggested repairs (and anyone's estimate on how much they should cost) are most appreciated
PW
Pontiac, MI
