Re: 1957 johnson 7.5
sounds like the tank is not holding pressure. there are 2 types of tanks, black plastic button, and metal button, the tanks take different rebuild kits. they are available at laingsoutboards.com. before that make sure there are no air leaks in any of the hoses, this would cause it to loose pressure, also. the way the system works, is , you pump the button to get gas to the carb, for start. on start the engine pumps air into the tank, pressurizing it, and forcing gas to the motor. thus if leaking anywhere, the gas does not get there. also the float needle valve in the carb could be sticking, and the air pressure may not be enough to force it open, where the pumping does. are you totally confused yet.
