  #1
Old July 8th, 2007, 05:29 PM
wycough wycough is offline
Default 1996 Mariner 115 carb screws????
I have a 1996 Mariner 115 that has the top two carbs with the adjustments screws. After a soft seat, how far out should they be turned out?
Thanks
  #2
Old July 8th, 2007, 06:05 PM
Silvertip Silvertip is offline
Default Re: 1996 Mariner 115 carb screws????
There is no exact setting but you can start at 1-1/4 turn. The "fine" adjustment must be made with the engine in the water -- not on muffs as there is no back pressure. Starting with the top carb, note the position of the screwdriver slot. Then turn the screw IN in 1/8 turn increments, pausing after each adjustment to let the engine stabilize. At some point the engine will begin to gag and tend to stall. Note that position. Now turn it in the opposite direction, again in 1/8 increments until the engine stalls. Happiness is somewhere in between the two stall points. Repeat on the other carbs. This process requires some patience and a good ear.
  #3
Old July 8th, 2007, 11:10 PM
Does the "idle screw" only adjust the idle or is that used in setting the timing? I did not adjust the timing stop screws. But, I did have to adjust the idle screw to get the idle down after getting the throttle cable correctly positioned.
  #4
Old July 9th, 2007, 02:15 AM
There are lots of screws to fiddle with but the idle timing and wide open throttle timing are two to keep your fingers off of unless you know what your are doing. The idle speed screw (only one of those) sets the idle rpm. Each carb has an idle mixture screw. Those normally have a spring under the head to keep them from working loose. On the 115 two of the carbs will not have idle mixture screws as two cylinders are killed at idle.
  #5
Old July 9th, 2007, 09:45 AM
I need to put a picture of the idle screw up to make sure I have the right one. The idle screw adjustment is the one I need. The idle timing and the wide open timing both have jam nuts on them, right? One at the top of the arm and one at the bottom of the arm.
The idle rpm adjustment screw is in the middle with the spring and white plastic, right?
My air/fuel mixture brass screws are set at 1 1/4 turns out. And I'm at 1200 rpm's on the muffs. I believe it should drop about 300 rpm's when in the water.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sea King carb screws setting? newboater74 Other Outboard Brands 7 March 31st, 2007 10:26 PM
1996 Mariner 150 carb problems ????? apextrail1 Mercury & Mariner Outboards 8 October 17th, 2006 05:25 PM
Carb rebuild loctite screws question h_lankford Johnson & Evinrude Outboards 5 January 8th, 2006 01:26 PM
Yamaha 90 Carb Pilot Screws Popeye 17 Yamaha & Suzuki Outboards 3 November 21st, 2002 08:56 AM
80 mercury..carb mixture screws crazyray Mercury & Mariner Outboards 2 August 26th, 2002 08:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
