LITTLE help
JAMESXUXA
I HAVE A 35HP LONGFOOT JOHNSON IT WILL START BUT THE TO COIL IS ONLY 1 THAT FIRES. I REPLACED THE BOTTOM COIL AND STILL WONT
FIRE. What is the problem . I can only think the power pack.
JAMESXUXA
Re: LITTLE help
[/QUOTE] I just need some help
fireman57
Re: LITTLE help
If you will post the model number we will know which year you are talking about. Physically remove and swap the coils and see if the problem follows. I know you said you replaced the bottom one but if it is one you had to put together yourself the wire might not be seated correctly.
