controll box 1985 90 hp
smitfire
I just bought a boat with a 1985 90 hp v 4 Johnson when I tried to start I was unsuccessful then i found out that the fast idle lever is not moving the cable ( plus I do not know if this model has a elec. choke or not )I opened the control box and see that a nylon part has been repaired and that the fast idle lever some how lost its connection with the parts in side also the man overboard switch is been removed and a black and a black with yellow wire are hanging loose now also the starter motor will not turn over ,my q. can i get spare or replacement parts for this control or em I just better of to by a new box and were? thanks already: Ron
tashasdaddy
Re: controll box 1985 90 hp
the black yellow wire are the kill wires for the engine. there are always controls on Ebay, ebay motor, boat parts, controls. you can try to get parts, diagram and parts list here, http://www.evinrude.com/en-US/Accessories/Literature/ on that model you turn the key to on and push the key in to activate the choke/primer.
