  #1
Old July 7th, 2007, 05:55 PM
Hamburgertrain Hamburgertrain is offline
Default Mercury 500 50hp 2 stroke not starting
It ran fine for about an hour and then it died out on the water. It started rough and died now it won't start. I changed the plugs, checked for spark, plenty of gas and ran out of ideas. I tested the motor this morning and was pumping water perfectly. Any suggestions?
  #2
Old July 7th, 2007, 05:58 PM
Laddies Laddies is online now
Default Re: Mercury 500 50hp 2 stroke not starting
Need to know the year
  #3
Old July 7th, 2007, 06:02 PM
1975 I believe. Thunderbolt ignition.
  #4
Old July 7th, 2007, 06:15 PM
Those driver thunderbolts are pretty trouble free, First disconnect the salmon and brown wires from the blue termial of the switchbox leave the blue wire hooked up. (this will disable the mercury switch and the boat wiring harness) YOU CAN'T SHUT THE ENGINE OFF with the key it must be choked off. If this does not correct the problem remove the dist. cap and clean it and the rotor with hot soapy water and a brush, then dry, ck the carbon in the cap and try the engine again.
  #5
Old July 7th, 2007, 08:23 PM
I tried that to no avail. Now I am thinking I am not getting gas, the carb is buried under a lot of stuff. Any suggestions on troubleshooting the gas supply?
  #6
Old July 7th, 2007, 09:49 PM
diaric's Avatar
diaric diaric is offline
try spraying some mixed gas or sea foam/deep creep in the carbs. if it fires then your onto something. if not check your spark. does the primer bulb pump up hard? does any fuel spill outta carbs when you do so?
  #7
Old July 8th, 2007, 12:16 AM
Thanks that worked. What do you suppose the problem was? I just sprayed gas in the carbs and vroooom. Was there a vapor lock? How can I protect against that occurring again?
  #8
Old July 8th, 2007, 01:22 AM
diaric's Avatar
got me. i expected it too start, run the gas and quit. signifying a fuel problem. lets hope it keeps running great
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 50hp 4-stroke starting problems stinga Yamaha & Suzuki Outboards 3 October 5th, 2008 03:27 PM
Honda 50hp vs. Mercury 50hp 4-stroke EFI redear Non-Repair Outboard Discussions 10 April 25th, 2005 01:31 PM
Honda 50hp vs. Mercury 50hp 4-stroke EFI redear Mercury & Mariner Outboards 2 April 18th, 2005 05:54 AM
Honda 50hp vs. Mercury 50hp 4-stroke EFI redear Honda & Tohatsu/Nissan Outboards 2 April 18th, 2005 05:49 AM
Mercury 50hp Starting problems. Roger2 Mercury & Mariner Outboards 6 September 20th, 2002 07:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
