  #1
Old July 7th, 2007, 02:35 PM
Larslars65 Larslars65 is offline
Default Evinrude 4hp starter-rope won't rewind
The starter-rope on my Evinrude 4hp (1980 mod) is only rewinding 2-3 inches. The rest I have to rewind myself ( by removing the top-cover while the engine is running ).
Is it something that is in need for some oil? Or some parts that need to be replaced??
  #2
Old July 7th, 2007, 04:20 PM
Lubosleftboot's Avatar
Lubosleftboot Lubosleftboot is offline
Thumbs up Re: Evinrude 4hp starter-rope won't rewind
Your return spring is either broken or very badly adjusted Lars...To find out you will need to remove the cowling and the pull start assembly...Turn the pull start assembly upside down and you will see a retaining nut in the centre that hold the return assembly together.Loosen this nut carefully and remove the guard plate (be careful as the return spring can jump out at you) and inspect the unit.
If the return spring is broken you will see this straight away and a new return spring will need to be fitted...
If the return spring is maladjusted then you can unhook one end of the return spring carefully and tighten the spring by takeing the hook of the return spring and turning it anti-clockwise two or three turns then relocate the end in its groove...This will tension the return spring.Re-assemble the return assembly and refit to your motor..
Hope this is of some help to you
LLB
__________________
Kermit Klein fashion guru to the stars...
  #3
Old July 7th, 2007, 04:51 PM
Default Re: Evinrude 4hp starter-rope won't rewind
Thanks for advice! My Evinrude is located in our summerhouse 350 km away from here. I will print out your instruction and bring it along for the next time going there. Thank you again.
  #4
Old July 7th, 2007, 07:35 PM
No worries Lars that is what this forum is for...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude starter rope bigkrof23 Johnson & Evinrude Outboards 9 June 13th, 2009 08:54 PM
30hp Evinrude Starter Rope WetDawg Johnson & Evinrude Outboards 5 December 7th, 2006 02:35 PM
1987 Evinrude 15 Rope Starter Problem 111torrance111 Johnson & Evinrude Outboards 1 March 6th, 2006 03:49 PM
6hp Evinrude - starter rope won't pull scctiger Johnson & Evinrude Outboards 2 February 16th, 2004 05:50 PM
Rewind starter on Evinrude 4.5 Old Salt Johnson & Evinrude Outboards 5 January 30th, 2004 10:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
