  #1
Old July 7th, 2007, 02:00 PM
jtowne jtowne is offline
Default Mariner 30hp milky lower unit oil
I am getting water in my lower unit oil. I was originally thinking it was the prop shaft seal but I don't leak oil while sitting there on the trailer so maybe it is the oil seal on the drive shaft. I found some fish line behind my prop when pulling it.
If it is the prop shaft does anyone know what wrench I need for the cover nut. Some kind of spanner wrench??
Mariner 30m (1982)
  #2
Old July 7th, 2007, 02:03 PM
Silvertip Silvertip is online now
Default Re: Mariner 30hp milky lower unit oil
Before going through that effort, drain the lower unit, replace the seals on the drain and vent screws. Refill the lower unit and run it again. If you still have water intrusion, then go after the prop and driveshaft seals. You really should have a manual for your manual to guide you in this effort. Try your local library. They may not have one for your exact engine but one that's close is better than none.
  #3
Old July 7th, 2007, 08:01 PM
jimmy57 jimmy57 is offline
i had the same issue with my 650 the waterpump base drive shaft seals were leaking i did find oil in the exhaust my prop shaft seals were always dry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Milky oil in lower unit.... 72Stinger Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 August 9th, 2004 08:30 AM
mariner 30hp lower unit Gibsjam Mercury & Mariner Outboards 0 April 11th, 2004 09:56 AM
Milky lower unit oil henryban Johnson & Evinrude Outboards 4 January 15th, 2004 02:36 PM
milky oil in lower unit terrys Johnson & Evinrude Outboards 5 July 13th, 2003 02:18 PM
Mariner 30hp lower unit problems trapperlon Mercury & Mariner Outboards 1 March 27th, 2003 12:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
