  #1
Old July 7th, 2007, 01:59 PM
brice1310 brice1310 is offline
Default Alarm continues to sound when engines running
I have a 1997 Bayliner 2050 SS. When I start the boat the alarm continues to sound and does not go off like it usually does. Does anyone know what may be causing this problem? Thanks.
  #2
Old July 7th, 2007, 03:31 PM
gcboat gcboat is offline
Default Re: Alarm continues to sound when engines running
Check all your fluid levels !!
  #3
Old July 7th, 2007, 04:08 PM
Thanks for the reply. I have only had the boat for a few months. Can list all of the fluids I need to check? Thanks!
  #4
Old July 7th, 2007, 06:34 PM
4runneradam 4runneradam is offline
Could be the high temp buzzer. Whats the temp gauge read?
  #5
Old July 8th, 2007, 08:38 AM
It should all be explained in your owner's manual. I'm not trying to blow this off but there are differences in boats and design. Best you do it right then for me to guess over a pc. But your oil level is a good place to start. As
4runneradam mentioned what is your water temp reading? How long do you let it run before shutting it down? Check your bilge, any oil in there? It also could be something as simple as a faulty sending unit - doubtful however. Sorry for being so vague.
  #6
Old July 16th, 2007, 12:54 PM
aqualight aqualight is offline
Check the gear lube fluid level. The sort of clear white container is in plain site in the upper right area on your engine if you are looking at from in the boat (if you have a mercruiser 3.0 Alpha). It has a bluish liquid in it
I had this happen to me and was just rip out the alarm because I couln't figure out why it was going off. Turns out I was below the fill mark.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
175 evinrude alarm sound at idle bigwave Johnson & Evinrude Outboards 1 January 12th, 2007 03:06 PM
alarm doesn't sound on startup dutch135 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 July 30th, 2004 01:55 PM
50hp Johnson-What is this alarm sound??? Shark Spit Johnson & Evinrude Outboards 3 July 29th, 2002 12:25 PM
continous alarm sound on 75hp Merc ob yf2k Mercury & Mariner Outboards 0 July 14th, 2002 10:13 AM
alarm (whistle sound) neptune202 Non-Repair Outboard Discussions 7 February 26th, 2002 07:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
