  #1
Old July 6th, 2007, 09:58 PM
sjp649 sjp649 is offline
Smile Mariner 150 not charging
I just got a 18ft Aries Bass boat with a 150 Mariner outboard. The motor is not charging. It always has a voltage reading of 12.6 volts while running. I performed a rectifier test as outlined in the seloc manual. It showed that the rectifier was bad. It had continuity all the time on all poles. I changed out the rectifier, it still did not charge, I rechecked the test, it had continuity on "A" and "C" with the positive and negative lead to ground, but from "B" to "A" and "C", it was open. Did I fry the rectifier, and have another problem? I then checked AC voltage straight out of the stator, one terminal, the voltage was switching good, the other did not move much. Bad stator as well? Did that fry the new rectifier? Please help, I really want to get fishing, but right now I don't want to shut the motor off, then get stranded. Also what year is the motor if anyone could tell me, the serial # is OB184363.
Thanks in advance,
Steve
  #2
Old July 6th, 2007, 10:40 PM
studlymandingo's Avatar
studlymandingo studlymandingo is offline
Default Re: Mariner 150 not charging
Welcome aboard iboats!!!
It does sound like you have a stator issue. Do you have a DVA meter?
__________________
The wetter, the better.
  #3
Old July 6th, 2007, 10:48 PM
Yes, I have a meter.
  #4
Old July 7th, 2007, 03:09 PM
Anyone have any ideas, my son is wanting to go out so bad.
  #5
Old July 13th, 2007, 05:42 PM
I took the flywheel off today, the stator was loose, all 4 bolts were loose. The inside of the flywheel was not damaged but it looked like it had wear marks on 1 side more than the other. The stator did not look bad, it wasn't melted, but 1 part was worn down from the flywheel rubbing on it. I tightened the stator down, and fired it back up, it was at 13.46 volts at the battery, so I thought everything was fine. I let it run for about 10 minutes, then went to fire it back up,and only the starter turned but did not engage the flywheel. Put the charger back on, fired it back up, now voltage was only 12.99 at the battery and at the rectifier. Please help me figure this out.
Steve
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60 hp mariner charging problem amot69 Mercury & Mariner Outboards 2 August 16th, 2006 03:49 AM
60 hp Mariner not charging amot69 Mercury & Mariner Outboards 2 August 15th, 2006 05:55 PM
Charging system ? 135 mariner bubbakat Mercury & Mariner Outboards 4 February 23rd, 2006 06:09 PM
add a charging system to old 4hp mariner tcook@nycap.rr.com Mercury & Mariner Outboards 3 October 24th, 2005 09:43 PM
Mariner 8 hp. - ? about charging system. mexmike Mercury & Mariner Outboards 1 August 4th, 2004 12:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
