Good morning, I have recently purchased a 1972 Renkin Bow Rider with a 50hp Evinrude. The past owner hadn't had the boat in the water for the last 5 years, but installed a new water pump. I finally got the engine to idle well, but when in gear, the boat won't get up to speed. The engine bogs down a little as the throttle is moved forward, then picks up a little speed (not much) as I move past that point. If the throttle is pushed all the way forward the engine sounds as if it will choke itself out. I first checked the fuel filter, (which isn't more that a little screen and cork gasket). I don't know what could be wrong there. Any suggestions on where to start? I'm mechanically inclined, Motorcycles, PWC's and cars, but this old boat engine stuff is new to me. Thanks in advance for any help.
-John
-John
