  #1
Old July 6th, 2007, 02:22 PM
pjsin pjsin is offline
Default Impeller replacement Yamaha 20b, where should water eject from?
Hi,
I have just aquired a yamaha 20b. The engine starts and runs well, though I am a little concerned as I can not see any water being ejected. I have purchased a replacement impeller and unsure how to fit it.
Please could you advise me where the water should be ejecting from please. Please see attached image
Any advise would be much appreciated.
Cheers,
Andrew
  #2
Old July 9th, 2007, 05:36 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default Re: Impeller replacement Yamaha 20b, where should water eject from?
nice motor, i have a 25 like that .... tip on this motor, mix the fuel/oil ... 50:1 and not 100:1 as it says on the cowling ..... anyway ..... I modified your pic a bit .... where I marked no.1 is where the motor should "pee" water from the tiny hole I circled, and sputter water from the arrow ..... sometimes the little hole can get blocked by insects and stuff so take a thin wire and wiggle it .... when replacing the impeller you must take off the bolts as marked 2. but remember that these break very easily and you have to pre treat these with a deep penetrating oil for at least 2 days by spraying every now and then ..... turn slowly and make sure it is the bolt that turns and not the head twisting ..... marked 3. is where you must disconnect the shift rod when dropping the lower unit .....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #3
Old July 9th, 2007, 05:37 AM
__________________
  #4
Old July 9th, 2007, 01:31 PM
Many thanks for your response, Your advice is really helpful, especally diagram. In future use a 50:1 mix. I'll let you know how I get on with impeller replacement. Cheers. Andrew
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
water impeller replacement tony57 Johnson & Evinrude Outboards 2 April 15th, 2007 09:45 PM
Yamaha F100 impeller replacement poulbr Yamaha & Suzuki Outboards 3 February 25th, 2006 11:59 PM
Impeller Replacement - Yamaha T9.9 EXRX Dave Bany Yamaha & Suzuki Outboards 0 May 28th, 2005 09:15 AM
Yammy water impeller replacement - How? trianj Non-Repair Outboard Discussions 1 October 27th, 2001 08:03 AM
Water Impeller Replacement johnno Mercury & Mariner Outboards 4 February 12th, 2001 03:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
