  #1
Old July 6th, 2007, 11:46 AM
lou_ky_it lou_ky_it is offline
Unhappy Front pads on 1988 Baja Islander 180
Ok, heres to hoping someone has had to do this before. The wood on the side pads of the open bow rotted and had to be replaced, getting it out was not to bad as the wood was rotted and the t-nuts rusted, broke t-nuts, bolts fell out with ease, ok, now I have to put them back and the starboard side is tight, but I can get a hand in there, however it's like they put the boat together to far to the port side and a hand will not fit up in there, any and all suggestions welcome, in other words HELPPPPPPP!!!!!!!!!!!!!!!
  #2
Old July 6th, 2007, 03:47 PM
rndn rndn is offline
Default Re: Front pads on 1988 Baja Islander 180
Is it possible to use an adhesive?
__________________
1996 Crestliner 2160 Phantom, 1996 Evinrude 130 HP
  #3
Old July 9th, 2007, 09:01 AM
I could have used an adhesive, but that is a whole new bag of worms when you have problems in the future with the wood, which btw was painted with thompsons wood seal in hopes that this does not happen again (-:
What I wound up doing was taping a small ratchet to a small peice of lumber about 1" x 1/2" x 1', then used a peice of paper towel in the socket so the bolt did not fall out while I lined it up, it worked just fine and the pads are back on.
  #4
Old July 4th, 2009, 10:20 PM
wotherspoon wotherspoon is offline
Just FYI...I recently had most of the wood on my 87 180 islander replaced. I thought just a couple of seats were bad but it turned out it was alot more extensive, most of the seats and all of the side panels. So I had it replaced and they used all new nuts because they were rusted. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
front disc brake pads sassboater Non-Boating Technical Topics 23 May 5th, 2006 04:44 AM
25 foot Baja Islander/ Sport Fish???? nicotroop Boat Topics and Questions (not engine topics) 6 August 29th, 2005 07:06 AM
25 foot Baja Islander/ Sport Fish???? nicotroop Baja Boats 6 August 29th, 2005 07:06 AM
prop size for a Baja 208 islander 454eng vicdur93 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 June 25th, 2004 08:10 PM
Stock prop size , Baja 208 islander 7.4 vicdur93 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 21st, 2004 11:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
