Cricket Too
- May 14, 2003
- 1,732
Hey guys,
Just bought a new to me boat, a 1997. Noticed that there is no battery switch on it, so I was gonna throw one in, but it occured to me that since this boat only has one battery, and I'm not planning on putting a second one in, do I really need to have a battery switch?
Do they provide any function other than switching between two batteries for charging/starting purposes? Do they provide any protection for anything?
I had a guy tell me that they are good in case the boat starts to go under at all, because if it's switched to OFF then you won't short any of your electronics, but it just seemed to me that it wouldn't matter, because once the switch went under, the saltwater would just short the switch and everything else, and just blow your fuses....not to mention that if my boat goes under, my battery switch and electronics will be the last of my worries.
Just thinking that if it's been OK for 10 years, why change it?
It's also got a biulge pump set up that I would need to swicth around in order to have constant power to the bulge pump float switch, which now runs up and is connected under the dash somehow.
So leaving it the way it is, is obviously easier, just wanted to see if it was not the right way.
Thanks.
Thanks.
