  #1
Old July 5th, 2007, 10:02 PM
eldon eldon is offline
Default starting problem, 1990 225 hp evinrude looper.
I just had the powerhead done last year and it has about 60 hrs on it to date,
added new timeing base, power pack, and the fly wheel is also new (magnets are good), compression is 90 psi on all six + or - 2 psi. this motor ran just fine until last weekend. At start up there is no fire on 3,4,6, then in about 4 seconds it start hitting on all six and runs fine, (checked it with a timing light) this has never happend before and is intermitent and happens more than not.
I do know there is a device that alternates firing on three cylinders when you are shifting the motor into gear but I'm not sure of the of the cylinders it affects, and I do not know where the device is installed on the motor or boat (not that its the problem) but a place to start.
Also does anyone know what the timing is atdc,this is at idle in gear?
If you've had this problem and got it fixed or know what to do to fix it, please let me know, and I'll put you on my Xmas card list for next year.
Best regards
eldon
  #2
Old July 6th, 2007, 12:27 AM
ezeke ezeke is offline
Default Re: starting problem, 1990 225 hp evinrude looper.
The switch is controlled by and located at the shift arm on the engine. You can disable it temporarily by disconnecting the switch's black ground wire from the block.
  #3
Old July 6th, 2007, 01:31 AM
Thanks for the responce, Is this the same switch that has the black with yellow marking? I'll try that this AM.
Ezeka thanks for the help, Have you heard of this happening befor? Would you happen to know the cylinders that are afected by this switch.
Again thanks for the help.
eldon
  #4
Old July 6th, 2007, 07:17 AM
The shift assist should affect cylinders 1,3 and 5 on the starboard bank.
The black and yellow wire is the kill wire for the shift assist. It controls by grounding out the powerpack on that side. It joins with the rest of the kill system and uses the same black and yellow wire, but there is a blocking diode on that side to prevent it from affecting the port cylinders.
Disconnecting the solid black wire prevents the switch from grounding the power pack.
  #5
Old July 6th, 2007, 09:42 AM
red boat red boat is offline
timing should be 6 deg at idle and 18 deg at WOT.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
problem starting 1990 175 johnson crossflow gloveman Johnson & Evinrude Outboards 4 January 29th, 2005 11:41 AM
1990 Evinrude 120 looper boating2fish Johnson & Evinrude Outboards 1 January 9th, 2005 05:08 AM
1990 force 120 starting problem mattldrive Force & Chrysler Outboards 1 June 19th, 2004 12:45 PM
1990 Evinrude 200 hp Big bore Looper RetNav Johnson & Evinrude Outboards 4 September 5th, 2003 04:57 AM
1990 200 hp Evinrude looper RetNav Johnson & Evinrude Outboards 4 September 3rd, 2003 02:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
