Trying to determine if the switch box is bad or if the problem may be the trigger coil or stator. There is no spark on lower cylinder and at times not on top cylinder. Have run ohm meter tests using Mercury repair manual as guide on stator, trigger coil, and ignition coils. All results were within the specified ranges except one stator test. The ohm meter reading across the two leads of stator was slightly lower than specified. The range is 3100-3700 ohms. The reading I got was 3070 ohms. Reversing the leads from one ignition coil to the other coil gave spark to the bottom cylinder and none to the top cylinder. Please anyone help me determine what part to replace.All these parts are costly so would like to get it right the first time.
