  #1
Old July 5th, 2007, 04:49 PM
solberg solberg is offline
Default 1990 40hp Evinrude Carb And Power Loss
Last Year I had carb problems, no high speed until I pushed the prime button, so I pulled them apart and cleaned the jets and all ports with spray carb cleaner. When I went out to run it, it was a little better at first but still couldn't get it to plane out. As I was going back to the launch, all of a sudden it just took off. Good speed and everything, so I figured the cleaning dislodged something and it finely opened up. I thought is was running fine until I went to pull my kid on a tube with it. It would usually snap them right up, but now it acts like it did before I cleaned the carbs, no power, and will not get up to speed. Without pulling anyone it seems to be running good. What do you guys think? I didn't put a carb kit in there because the parts shop said I was wasting my money. Should I pull the carbs apart and soak them then spray them out? I don't even know if it was the carbs the way it was doggy right after I cleaned them and then all of a sudden it took off. Any suggestions would be appreciated.
Thanks
  #2
Old July 5th, 2007, 06:06 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 1990 40hp Evinrude Carb And Power Loss
Have you checked to see if your battery is supplying enough juice? Checked the battery connections at the battery and on the motor? There could also be some left over junk from when you cleaned your carbs. Is the motor overheating at all? Have you done a compression test?
Try cleaning all the coils and block where they ground to the block.GL
__________________
Chris
  #3
Old July 5th, 2007, 06:43 PM
I hav'nt checked the connections this year, but I know I did last year and that didn't change anything, although it would be a cheaper and easier fix problem to have. The motor isn't overheating, and no I havn't done a compression check, too afraid to. If the compression was bad, that would be to much jing to fix for me to have a boat for awhile. So we don't want to think about that one. I'll try and clean the coil connections and hope for the best.
  #4
Old July 5th, 2007, 09:22 PM
Silvertip Silvertip is offline
Once the engine starts, the battery has nothing to do with anything as the stator is providing the current to run the motor. You said the engine seems to run good -- well, if it has no power it isn't running good. Check for spark on both cylinders. I suspect you have an ignition problem and the engine is dropping a cylinder.
  #5
Old July 6th, 2007, 12:05 PM
Ya, I appreciate any help, but I don't think it is a current problem. When I'm not pulling anybody and it's just two of us in the boat it seems to get up and go good, well come to think of it, it's not as good as before I had to clean the carbs. When you say an ignition problem, do you mean when there is a load and I give it gas it's cutting ignition to a cylinder? or no spark anytime? I have checked the spark when parked at the dock and there is spark to both. Would rebuilding the fuel pump do anything? or cleaning it out? Or should I do a total rebuild of the carbs? Also, what am I going to find when I open up that pump cover? I hate opening things up for the first time only to have a important piece fly out and land in the water or something.
Like I said before, I really appreciate the help.
  #6
Old July 6th, 2007, 12:43 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
check your compression, may have a weak cylinder. but, i'm really betting you did not remove the high speed jets and clean them, special screwdriver required. and the reassembly with a rebuild kit.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 40HP loss of power after 30 mins. running monoshock Johnson & Evinrude Outboards 24 July 2nd, 2005 08:11 PM
1990 50 hp evinrude loss power on turn couch12 Johnson & Evinrude Outboards 1 July 9th, 2004 05:45 AM
1990 50 hp evinrude loss power on turn couch12 Non-Repair Outboard Discussions 0 July 8th, 2004 06:37 PM
1990 evinrude 120 power loss cogonc Johnson & Evinrude Outboards 9 January 30th, 2004 04:30 PM
1990 Evinrude 70 HP loss of power waterskidi Johnson & Evinrude Outboards 0 July 1st, 2002 06:26 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
