  #1
Old July 5th, 2007, 12:25 AM
zit zit is offline
Default 20 hp evinrude kick out of forward and goes to neutral please help
hi i recently purchased my first used boat and motor with a 1983 20hp evirude, it kicked out of forward at a moderate speed and went into neutral and reved high.
i released the trottle put it back to shift and put it back into forward, however it sound like it something was slipping, power was no longer there and i barely made it back to shore.
i read this site suggestions and found the forward and reverse gear to be fine and same with the pinion gear to be fine also. The clutch looks fine also and the dogs look mew.
I also looked at the prop to determine wether it my have spun on the bushing, it looked fine also.
I have also checked the shift rod connector it was fine, can anyone offer me any other suggestions what to check next.
when this occured i was going upstream at a moderate speed and fighting a lot of current.
I appreciate any advice you can provide me with, and thank you in advance.
  #2
Old July 5th, 2007, 12:41 AM
samo_ott's Avatar
samo_ott samo_ott is offline
Default Re: 20 hp evinrude kick out of forward and goes to neutral please help
One of the items you listed above is the culprit. Make sure you are checking them all correctly. Chances are you have lower gear problems.
  #3
Old July 5th, 2007, 03:18 AM
diggerdan17 diggerdan17 is offline
i had a 35 horse johnson of similar era and i thought the clutch dogs looked to be in good condition.turns out they were very slightly worn and it was just enough to kick it out of gear.
  #4
Old July 5th, 2007, 04:44 AM
kmk_7110 kmk_7110 is offline
If its spinning on the bushing you'll know in the water but it can be tricky when out of water. The water creates the force so on land just put the motor in gear and try to turn the prop. You know the rest.
  #5
Old July 5th, 2007, 05:45 AM
F_R F_R is offline
Very simple. Does it make a grinding noise when it is "barely making it back to shore"? Does, doesn't it? You said it is actually kicking the shift lever back to neutral. That is the dog and gear. You aren't seeing what you are looking at.
A spun prop will slip smothly, like spinning your wheels on ice.
A dog will jump out of gear, grind, sound like you ran over something.
A broken shear pin will....well, I guess you don't have one of those, do you?
Could be stripped drive / crank shaft splines too. In that case it wouldn't go, period.
Also could be something in the shift linkage, not actually putting it in gear, or not all the way into gear.
Gotta be one of the above.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wont go into neutral or reverse, stuck in forward shute421 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 July 11th, 2006 04:00 PM
Engine Stalls when shifting from Forward to Neutral or Reverse to Neutral jules03 Johnson & Evinrude Outboards 6 May 10th, 2006 07:21 AM
Noise when shifting from Neutral to Forward/Reverse Technician Force & Chrysler Outboards 4 June 11th, 2005 05:12 PM
wont shift to neutral from forward throttle seafox23 Johnson & Evinrude Outboards 0 April 28th, 2003 07:17 AM
Revs good in neutral but not in forward Bueller Johnson & Evinrude Outboards 1 July 7th, 2001 09:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
