  #1
Old July 4th, 2007, 08:40 PM
First baybee First baybee is offline
Default Refilling Fuel spillage problem advice?
Help!
I recently brought home a used 2005 Capri 175 BR and upon driving her home this past tuesday, stopped for fuel.
Upon gassing her up, the nozzle at the gas station kicked off but the gas tank regurgitated about a pint of gasoline all over the back of my boat.
Today I took this boat out for her maiden voyage and burned not quite half a tank of gas, so on the way home I decided to fill up again. This time I held the nozzle and fed the gas in slowly (with the nozzle down the spout) and again I wound up with about a pint of gas coming back out the filler spout all over the boat and my hand.
Is there a secret to putting gasoline safely into these boats? I'm growing tired of smelling like gasoline after mopping up the mess..
Advice appreciated!
  #2
Old July 4th, 2007, 08:46 PM
Rob454 Rob454 is offline
Default Re: Refilling Fuel spillage problem advice?
I usually put the gas in 5 gallon gas cans ( I use the same gas cans motorcycle dirt riders use big square gas cans) and then fill it up at home.
If I go to the gas station I usually fill it up then stop after every 5 gallons or so. Sometimes the vents on the gas pumps arent working right. Also check and make sure your vent hose isnt kinked. that could cause the problem youre having. mine was so kinked up it woudl spill gas constantly until I fixed the vent hose
Rob
  #3
Old July 4th, 2007, 08:56 PM
Thanks for your suggestion. I like both of them. I'll trace the vent hose and see if thats the cause first and as a fall back I will fill cans and top off the tank at home slowly.
What a mess.... Dangerous too....
Loved the boat today though. Except I roughed up the skeg and prop today in shallow waters, which was totally unexpected. I think I'll put a skeg protector on there and a planing wing too bolted right to the outdrive. Had the 3.0 up to 43 mph today with three on board. Fun little boat!
  #4
Old July 5th, 2007, 02:23 PM
WAVENBYE2's Avatar
WAVENBYE2 WAVENBYE2 is offline
Send a message via Yahoo to WAVENBYE2
Just don't squeeze the handle all the way and you should not have any probs. the tube is small than auto's. I did the same when we first got her, just ease up and fill her up.>>>Pat
__________________
1991 Bayliner Capri 2050CX,4.3L V6,Mercarb 2bbl,Alpha 1
(QUOTE): When our boat is happy, THEN we are Happy
  #5
Old July 12th, 2007, 06:50 PM
GHMJR GHMJR is offline
I have a 2007 175 and it does the same thing , i cant beleive the hose would be kinked it pretty much dumps right into the gas tank I spilled more than a couple ounces when I did it though.
  #6
Old July 13th, 2007, 01:45 PM
coreyva coreyva is offline
If you go the way of using 5 gallon cans, these are great to siphon with. I've had one in my jeep for years. I picked mine up at pepboys.
  #7
Old July 13th, 2007, 03:16 PM
rondi rondi is offline
Guys, guys, this one is very simple.
The 175 on a trailer needs the rear jump seat cushions and seat backs removed or else they will blow away on the highway. When you fill up at the station and as you're pumping just look at the tank, it's clear plastic. Before it gets to the top stop pumping. No need to fill it to the brim.
Once I figured this out I have never spilled a drop on the transom again.
  #8
Old July 13th, 2007, 06:14 PM
gcboat gcboat is offline
You might also take a look at the thru hull vent. Mud dauber's, wasp's, etc. just love to build little nest's in there. Now that could also be a problem.
I know all of them should be screened but -------------.
  #9
Old July 14th, 2007, 11:18 PM
Ken_P Ken_P is offline
Had the same problem with my '06 trust me this tip works. Also you want to give some room for expansion if you are parking with the tank full. Otherwise it will expand and come out of the same vent...You might have bigger problems if you park in a garage with a heater / hot water heater.
__________________
175BR NAVMAN 4150sx, Garmin 76Cx, Minn Kota power drive w/copiolt, happy troller, 2 rod holders, 2 Attwood Mini Riggers.
  #10
Old July 15th, 2007, 12:12 AM
bbrnhart bbrnhart is offline
Replace the vent fitting. The cheap zamac vents corrode on the inside and plug the vent. When you fill the tank and the vent is not working you're building up pressure in the tank untill it has no where to burp but out the fill spout. Replaced mine and I never had a problem again.
  #11
Old July 15th, 2007, 12:41 AM
Quote:
Even on a new boat. Mine had done this since day 1. It spit up on me twice before I realized I can pull the seat cover and monitor how much fuel I'm adding. I was kind of blown off at the dealer when I told them about the problem and the fumes in the garage around the back of the boat. I've found that if I don't fill it to the top, the boat does not vent as bad in the garage.
-BTW what brand of vent did you replace it with? Do you have a part number?
__________________
  #12
Old July 15th, 2007, 11:53 AM
I actually did not replace mine. I took the screen out. Stick a scewdriver in it and tear it out. The screen plugs with the slightest corrosion.
  #13
Old August 5th, 2007, 02:41 AM
Wotam Wotam is offline
I have faced the same problem on my 195 classic. The 'burp' is caused by the fact that they mounted both the filler and vent on the 'low side' (aft) end of the tank. (convenient for the mfg, but causes problems)
If the boat is sitting slightly bow-up a trapped air bubble will form in the front of the tank when the fuel reaches the level of the filler/vent fittings... it compresses slightly, then belches gas. If you listen carefully to the sound of the fuel going in the tank you will hear a distinct 'gurgle' when the vent level is reached. Stop fueling immediately when you hear it!
When fueling on the lake, I have the passengers sit in the front of the boat, this puts the vent and filler on the 'uphill' side and the tank fills pretty nicely... and completely. I still keep a rag handy though, cupped under the filler opening... and listen carefully so I can hear when the fuel starts to come up the filler hose.
What attitude is the boat sitting when it's 'on the hitch'? If you are 'bow high' you may have bigger fueling problems... adjusting the attitude (with a drop hitch) of the trailer so the boat sits level may help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Refilling 5# propane tank? ZmOz Non-Boating Technical Topics 7 November 16th, 2005 03:41 PM
Refilling engine H2O after draining rebars1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 February 15th, 2005 04:27 AM
Fuel Spillage orion208 Boat Topics and Questions (not engine topics) 3 July 26th, 2003 09:33 PM
Mercury 135 2-Cycle oil tank not refilling. embimp Mercury & Mariner Outboards 1 June 21st, 2003 07:20 PM
Refilling your own inkjet printer cartridges lakeman1999 Dockside Chat 5 May 26th, 2003 10:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
