  #1
Old July 4th, 2007, 04:37 PM
rruberto rruberto is offline
Default 9.8 Mercury 110 - Exhaust Plate removal
Hello All, when removing the exhaust plate on the side of the engine, will something pop out, or this procedure is safe?
Can I remove the exhaust plate without removing th epower head?
Thank you all!
  #2
Old July 4th, 2007, 05:18 PM
Laddies Laddies is offline
Default Re: 9.8 Mercury 110 - Exhaust Plate removal
Nothing is loose under the covers, some can be removed without removing the engine but in most cases it's easier to track down the problem, a step at a time removing the powerhead to ck the w/tube grommet, then the exhaust covers and then the water jacket cover if is nessicary
  #3
Old July 4th, 2007, 05:30 PM
Wow Laddies.... i sure have to admit that you know your stuff! I looked at the exhaust plate and figured that it could be removed without removing the whole powerhead.
I will let you know how it goes!
Thanks!
  #4
Old July 4th, 2007, 11:31 PM
emckelvy emckelvy is offline
Be careful of how hard you twist on those 1/4-20 manifold bolts. If any of them require more than "gentle" force, stop and first heat up the area with a propane torch and they should come loose.
Otherwise you may break bolts and that repair is No Fun!!
Spread a thin coating of Permatex #3 Aviation-Type non-hardening gasket dressing on each bolt when you put it back together, and they'll always come out if needed in the future. Most auto parts stores carry small bottles of #3 with an applicator brush.
HTH........ed
  #5
Old July 5th, 2007, 12:51 PM
Emckelvy, sound like you had a nasty experience with those bolts! I will try tonight and pick up some of that aviation stuff!
Thanks for your help!
  #6
Old July 5th, 2007, 12:56 PM
We have plenty of Salty Dogs out here in the Beautiful Pacific Northwest!!!
You learn to use the Mercury Wrench (lotsa heat) so you don't have to replace all the nasty broken bolts with Heli-Coils!
It also makes you appreciate it when you get in a fresh-water motor, so easy to work on. Guys in the Midwest etc with all the lakes and large bodies of fresh water have it made!
  #7
Old July 5th, 2007, 01:07 PM
Harker Harker is offline
You will need new gaskets if you take it off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Is the exhaust plate SS? bretto Force & Chrysler Outboards 7 October 8th, 2006 03:10 PM
Exhaust Plate hamburgerman Johnson & Evinrude Outboards 0 June 12th, 2006 06:02 PM
troll plate removal chewyj Mercury & Mariner Outboards 5 February 8th, 2006 03:38 AM
Exhaust plate removal... ZmOz Mercury & Mariner Outboards 7 April 18th, 2004 08:43 PM
Exhaust Port Plate Removal kwk Force & Chrysler Outboards 2 July 28th, 2003 04:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
